Ubuntu 16.04 gnome版,插上WN725N无线网卡后,会死机
- 系统: win7
如题,我安装的是Gnome3的ubuntu,插上TP-LINK的无线网卡后,连接无线网就会死机,使用腾达或者水星的无线网卡就没问题,请问这个如何解决?
Re: Ubuntu 16.04 gnome版,插上WN725N无线网卡后,会死机
插入WN725N无线网卡,执行以下指令将结果全部复制贴上来
uname -a
lsusb
sudo lshw -C net
- 系统: win7
chris@chris-Inspiron-620s:~$ uname -avickycq 写了:插入WN725N无线网卡,执行以下指令将结果全部复制贴上来代码: 全选
uname -a lsusb sudo lshw -C net
Linux chris-Inspiron-620s 4.4.0-64-generic #85-Ubuntu SMP Mon Feb 20 11:50:30 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
chris@chris-Inspiron-620s:~$ lsusb
Bus 002 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 004: ID 1d57:ffa8 Xenta
Bus 001 Device 003: ID 046d:c52e Logitech, Inc. MK260 Wireless Combo Receiver
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
chris@chris-Inspiron-620s:~$ sudo lshw -C net
[sudo] chris 的密码:
*-network
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 06
serial: d0:67:e5:25:aa:6c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:27 ioport:d000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
*-network DISABLED
physical id: 1
bus info: usb@2:1.3
logical name: wlx14cf92184dd9
serial: 14:cf:92:18:4d:d9
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl8192cu driverversion=4.4.0-64-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bgn
- 系统: win7
[sudo] chris 的密码:
*-network
physical id: 0
version: 06
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network DISABLED
physical id: 1
bus info: usb@2:1.3
使用无线网卡导致死机是可能是驱动质量不佳所致。您可以尝试使用经过网友补丁的 reaktek 官方驱动,如 https://github.com/pvaret/rtl8192cu-fixeshuiyichris 写了: Bus 002 Device 005: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
(原版官方驱动可能无法在较新的内核上使用)(rtl8192cu 驱动适用于 rtl8188cus)
