ubuntu16.04.1安装rt3070网卡后,无网络
- 系统: ubuntu win7
ubuntu16.04.1安装rt3070网卡驱动后,禁用rt2800usb后,重启,没有网络了,怎么解决?
jacob2022s@gmail.com
Re: ubuntu16.04.1安装rt3070网卡后,无网络
1. 请提供“rt3070网卡驱动”下载地址ethan2016s 写了:ubuntu16.04.1安装rt3070网卡驱动后
2. 请提供主楼操作参考的文章
3. 插入网卡执行以下指令将结果全部复制贴上来
uname -a
lsusb
sudo lshw -C net
cat /etc/modules
cat /etc/modules-load.d/*
grep -Ri 'rt\|mt' /etc/modprobe.d/
- 系统: ubuntu win7
按照这篇文章第4个answer所说的操作的
http://askubuntu.com/questions/457061/r ... stallation
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/RT3070STA-master$ uname -a
Linux jacob-Mai-II 4.4.0-64-generic #85-Ubuntu SMP Mon Feb 20 11:50:30 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/RT3070STA-master$ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 005: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 004: ID 8087:07dc Intel Corp.
Bus 001 Device 006: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 04f2:b506 Chicony Electronics Co., Ltd
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/RT3070STA-master$ sudo lshw -C net
[sudo] password for jacob:
*-network
product: Wireless 3160
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:07:00.0
logical name: wlp7s0
version: 83
serial: 00:1e:64:f4:62:08
width: 64 bits
clock: 33MHz
configuration: broadcast=yes driver=iwlwifi driverversion=4.4.0-64-generic firmware=17.352738.0 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
resources: irq:33 memory:d3500000-d3501fff
*-network
product: AR8161 Gigabit Ethernet
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:08:00.0
logical name: enp8s0
version: 10
serial: 543a:47:f2:a5
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=alx latency=0 link=no multicast=yes port=twisted pair
resources: irq:34 memory:d3400000-d343ffff ioport:3000(size=128)
*-network
physical id: 3
bus info: usb@1:1.2.1
logical name: wlx008a1f34350b
serial: 00:8a:1f:34:35:0b
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rt2800usb driverversion=4.4.0-64-generic firmware=0.29 ip=192.168.1.114 link=yes multicast=yes wireless=IEEE 802.11bgn
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/RT3070STA-master$ cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/RT3070STA-master$ cat /etc/modules-load.d/*
# Parallel printer driver modules loading for cups
# LOAD_LP_MODULE was 'yes' in /etc/default/cups
lp
ppdev
parport_pc
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/RT3070STA-master$ grep -Ri 'rt\|mt' /etc/modprobe.d/
/etc/modprobe.d/blacklist-oss.conf:blacklist forte
/etc/modprobe.d/blacklist-oss.conf:blacklist uart401
/etc/modprobe.d/blacklist-oss.conf:blacklist uart6850
/etc/modprobe.d/blacklist-rare-network.conf:# security flaws discovered. In an effort to reduce the scope of future
/etc/modprobe.d/blacklist.conf:# snd_intel8x0m can interfere with snd_intel8x0, doesn't seem to support much
/etc/modprobe.d/blacklist.conf:# hangs at desktop session start (Ubuntu: #246969)
/etc/modprobe.d/blacklist.conf:# EDAC driver for amd76x clashes with the agp driver preventing the aperture
/etc/modprobe.d/blacklist.conf:#blacklist rt2800usb
/etc/modprobe.d/blacklist-framebuffer.conf:# Framebuffer drivers are generally buggy and poorly-supported, and cause
/etc/modprobe.d/alsa-base.conf:# Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
/etc/modprobe.d/alsa-base.conf:options snd-cmipci mpu_port=0x330 fm_port=0x388
现在为了上网,我把backlist rt2800usb注释掉了,我的网卡是rt3070usb的,用rt2800usb上网速度很慢,只有30多KB,以上供分析...
*-network
physical id: 0
version: 83
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 3
lp
ppdev
parport_pc
- 系统: ubuntu win7
*-network
physical id: 0
version: 83
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 3
lp
ppdev
parport_pc
*-network
physical id: 0
version: 83
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 3
lp
ppdev
parport_pc
- 系统: ubuntu win7
*-network
physical id: 0
version: 83
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 3
lp
ppdev
parport_pc
*-network
physical id: 0
version: 83
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 3
lp
ppdev
parport_pc
请提供“rt3070网卡驱动”下载地址。ethan2016s 写了:按照这篇文章第4个answer所说的操作的
链接是否贴错了,其中没发现 rt3070 相关内容,只有 mt7601(u) 的驱动安装说明。
首先您要确定 rt3070sta 驱动模块成功构建。执行 make 时,注意观察。
“重启,没有网络了”,在重启之前,先卸载 rt2800usb,加载刚刚编译的模块,看能否驱动。
若能驱动,再将刚刚编译的模块加入到 /etc/modules,确保开机自动加载。
- 系统: ubuntu win7
我的网卡是拓实N95,在拓实官网下载linux驱动,编译出错,所以之后在网上搜索rt3070的驱动,安装mt7601驱动,能装上.
cc1: some warnings being treated as errors
scripts/Makefile.build:258: recipe for target '/home/jacob/Documents/无线网卡驱动/rt3070/Linux系统/DPO_RT5572_LinuxSTA_2.6.1.3_20121022/os/linux/../../sta/sta_cfg.o' failed
make[2]: *** [/home/jacob/Documents/无线网卡驱动/rt3070/Linux系统/DPO_RT5572_LinuxSTA_2.6.1.3_20121022/os/linux/../../sta/sta_cfg.o] Error 1
Makefile:1420: recipe for target '_module_/home/jacob/Documents/无线网卡驱动/rt3070/Linux系统/DPO_RT5572_LinuxSTA_2.6.1.3_20121022/os/linux' failed
make[1]: *** [_module_/home/jacob/Documents/无线网卡驱动/rt3070/Linux系统/DPO_RT5572_LinuxSTA_2.6.1.3_20121022/os/linux] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.4.0-64-generic'
Makefile:388: recipe for target 'LINUX' failed
make: *** [LINUX] Error 2
- 系统: ubuntu win7
在github上找到的RT3070的驱动,编译同样出错,
https://github.com/DeDf/RT3070_Linux_STA_V2.5.0.3
scripts/Makefile.build:258: recipe for target '/home/jacob/Documents/无线网卡驱动/RT3070_Linux_STA_V2.5.0.3-master/os/linux/../../sta/sta_cfg.o' failed
make[2]: *** [/home/jacob/Documents/无线网卡驱动/RT3070_Linux_STA_V2.5.0.3-master/os/linux/../../sta/sta_cfg.o] Error 1
Makefile:1420: recipe for target '_module_/home/jacob/Documents/无线网卡驱动/RT3070_Linux_STA_V2.5.0.3-master/os/linux' failed
make[1]: *** [_module_/home/jacob/Documents/无线网卡驱动/RT3070_Linux_STA_V2.5.0.3-master/os/linux] Error 2
Makefile:356: recipe for target 'LINUX' failed
- 系统: ubuntu win7
在github上找的第2个驱动,还是编译出错,
https://github.com/comag/DPO_RT3070_Lin ... 4_20100604
scripts/Makefile.build:258: recipe for target '/home/jacob/Documents/无线网卡驱动/DPO_RT3070_LinuxSTA_V2.3.0.4_20100604-master/os/linux/../../os/linux/sta_ioctl.o' failed
make[2]: *** [/home/jacob/Documents/无线网卡驱动/DPO_RT3070_LinuxSTA_V2.3.0.4_20100604-master/os/linux/../../os/linux/sta_ioctl.o] Error 1
Makefile:1420: recipe for target '_module_/home/jacob/Documents/无线网卡驱动/DPO_RT3070_LinuxSTA_V2.3.0.4_20100604-master/os/linux' failed
make[1]: *** [_module_/home/jacob/Documents/无线网卡驱动/DPO_RT3070_LinuxSTA_V2.3.0.4_20100604-master/os/linux] Error 2
Makefile:275: recipe for target 'LINUX' failed
- 系统: ubuntu win7
lsmod只有rt2800usb
jacob@jacob-Mai-II:~/Documents/无线网卡驱动/DPO_RT3070_LinuxSTA_V2.3.0.4_2010060
4-master$ lsmod
Module Size Used by
drbg 32768 1
ansi_cprng 16384 0
ctr 16384 2
ccm 20480 2
rfcomm 69632 2
bnep 20480 2
rt2800usb 28672 0
rt2x00usb 24576 1 rt2800usb
rt2800lib 94208 1 rt2800usb
rt2x00lib 57344 3 rt2x00usb,rt2800lib,rt2800usb
crc_ccitt 16384 1 rt2800lib
arc4 16384 4
iwlmvm 311296 0
mac80211 737280 4 rt2x00lib,rt2x00usb,rt2800lib,iwlmvm
uvcvideo 90112 0
videobuf2_vmalloc 16384 1 uvcvideo
videobuf2_memops 16384 1 videobuf2_vmalloc
videobuf2_v4l2 28672 1 uvcvideo
snd_hda_codec_hdmi 53248 1
intel_rapl 20480 0
x86_pkg_temp_thermal 16384 0
intel_powerclamp 16384 0
coretemp 16384 0
videobuf2_core 36864 2 uvcvideo,videobuf2_v4l2
iwlwifi 200704 1 iwlmvm
snd_hda_codec_realtek 86016 1
snd_hda_codec_generic 77824 1 snd_hda_codec_realtek
kvm_intel 172032 0
snd_hda_intel 40960 6
v4l2_common 16384 1 videobuf2_v4l2
snd_hda_codec 135168 4 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel
videodev 176128 4 uvcvideo,v4l2_common,videobuf2_core,videobuf2_v4l2
kvm 544768 1 kvm_intel
irqbypass 16384 1 kvm
snd_hda_core 73728 5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
crct10dif_pclmul 16384 0
snd_hwdep 16384 1 snd_hda_codec
crc32_pclmul 16384 0
media 24576 2 uvcvideo,videodev
ghash_clmulni_intel 16384 0
cfg80211 565248 4 iwlwifi,mac80211,rt2x00lib,iwlmvm
snd_pcm 106496 4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
snd_seq_midi 16384 0
aesni_intel 167936 4
btusb 45056 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 32768 1 snd_seq_midi
btrtl 16384 1 btusb
btbcm 16384 1 btusb
rtsx_pci_ms 20480 0
memstick 20480 1 rtsx_pci_ms
btintel 16384 1 btusb
joydev 20480 0
aes_x86_64 20480 1 aesni_intel
bluetooth 520192 29 bnep,btbcm,btrtl,btusb,rfcomm,btintel
snd_seq 69632 2 snd_seq_midi_event,snd_seq_midi
lrw 16384 1 aesni_intel
input_leds 16384 0
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
gf128mul 16384 1 lrw
serio_raw 16384 0
glue_helper 16384 1 aesni_intel
snd_timer 32768 2 snd_pcm,snd_seq
ablk_helper 16384 1 aesni_intel
snd 81920 23 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
soundcore 16384 1 snd
cryptd 20480 3 ghash_clmulni_intel,aesni_intel,ablk_helper
shpchp 36864 0
mei_me 36864 0
lpc_ich 24576 0
mei 98304 1 mei_me
mac_hid 16384 0
parport_pc 32768 0
ppdev 20480 0
lp 20480 0
parport 49152 3 lp,ppdev,parport_pc
autofs4 40960 2
hid_generic 16384 0
usbhid 49152 0
hid 118784 2 hid_generic,usbhid
rtsx_pci_sdmmc 24576 0
nouveau 1495040 0
i915 1208320 6
psmouse 131072 0
mxm_wmi 16384 1 nouveau
ttm 94208 1 nouveau
i2c_algo_bit 16384 2 i915,nouveau
rtsx_pci 53248 2 rtsx_pci_ms,rtsx_pci_sdmmc
drm_kms_helper 155648 2 i915,nouveau
ahci 36864 2
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
libahci 32768 1 ahci
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
drm 364544 10 ttm,i915,drm_kms_helper,nouveau
alx 36864 0
mdio 16384 1 alx
wmi 20480 2 mxm_wmi,nouveau
video 40960 2 i915,nouveau
fjes 28672 0
4-master$ lsmod
Module Size Used by
drbg 32768 1
ansi_cprng 16384 0
ctr 16384 2
ccm 20480 2
rfcomm 69632 2
bnep 20480 2
rt2800usb 28672 0
arc4 16384 4
iwlmvm 311296 0
uvcvideo 90112 0
intel_rapl 20480 0
coretemp 16384 0
kvm_intel 172032 0
btusb 45056 0
btrtl 16384 1 btusb
btbcm 16384 1 btusb
rtsx_pci_ms 20480 0
joydev 20480 0
input_leds 16384 0
serio_raw 16384 0
shpchp 36864 0
mei_me 36864 0
lpc_ich 24576 0
mei 98304 1 mei_me
mac_hid 16384 0
parport_pc 32768 0
ppdev 20480 0
lp 20480 0
autofs4 40960 2
hid_generic 16384 0
usbhid 49152 0
nouveau 1495040 0
i915 1208320 6
psmouse 131072 0
ttm 94208 1 nouveau
ahci 36864 2
alx 36864 0
mdio 16384 1 alx
fjes 28672 0
- 系统: ubuntu win7
在synaptic中(加了kali的源后),有个firmware支持3070chipset,可是安装时候报错,
E: /var/cache/apt/archives/firmware-ralink_0.44kali1_all.deb: trying to overwrite '/lib/firmware/rt2561s.bin', which is also in package linux-firmware 1.157.8
- 系统: ubuntu win7
(Reading database ... 433368 files and directories currently installed.)
Preparing to unpack .../firmware-ralink_0.44kali1_all.deb ...
Unpacking firmware-ralink (0.44kali1) ...
dpkg: error processing archive /var/cache/apt/archives/firmware-ralink_0.44kali1_all.deb (--unpack):
A package failed to install. Trying to recover:
- 系统: ubuntu win7
以上是synaptic中安装firmware(支持3070chipset的) 的出错信息..
- 系统: ubuntu win7
在以下网址找到方法,试试看行不行?
askubuntu.com/questions/148767/help-do-i-install-the-ralink-rt3070-wireless-driver
官方驱动很少维护,一般发布后一段时间就不再适用于新的内核。7年前发布的驱动不经修改一般无法在 Linux 4.4 上编译通过。ethan2016s 写了:我的网卡是拓实N95,在拓实官网下载linux驱动,编译出错,在github上找的第2个驱动,还是编译出错,
mt7601 驱动应该无法驱动 2870/3070ethan2016s 写了:所以之后在网上搜索rt3070的驱动,安装mt7601驱动,能装上.
1. kali 基于 debian,ubuntu 使用 kali 源预计会造成严重问题。建议立刻移除 kali 源,不要执行任何安装/升级操作。您看到的错误是 debian 的 firmware-ralink 和 ubuntu 的 linux-firmware 冲突所致。ethan2016s 写了:在synaptic中(加了kali的源后),有个firmware支持3070chipset,
2. 您目前的问题是没有驱动,不是没有固件。
