ubuntu环境下如何使用TP-LINK WN826N USB无线网卡上网
- 系统: windows 7 ; ubuntu
ubuntu环境下如何使用TP-LINK WN826N USB无线网卡上网 求助,紧急,找了半天主题都找不到,谢谢
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
Re: ubuntu环境下如何使用TP-LINK WN826N USB无线网卡上网
插入此USB无线网卡执行以下指令将结果全部复制贴上来
uname -a
cat /etc/issue
lsusb
sudo lshw -C net
看不懂,请问有没有现成的教程
Linux canchenolubuntu-Lenovo 4.4.0-21-generic #37-Ubuntu SMP Mon Apr 18 18:33:37 UTC 2016 x86_64 x86_64 x86_64 GNU/Linuxvickycq 写了:插入此USB无线网卡执行以下指令将结果全部复制贴上来代码: 全选
uname -a cat /etc/issue lsusb sudo lshw -C net
Ubuntu 16.04 LTS \n \l
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 003: ID 0bda:818b Realtek Semiconductor Corp.
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 007: ID 2a45:2008 Meizu Corp. MX Phone (MTP)
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
*-network
product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
physical id: 5
bus info: pci@0000:02:05.0
logical name: enp2s5
version: 10
serial: 08:57:00:dd:61:d2
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
resources: irq:20 ioport:d000(size=256) memory:fd120000-fd1200ff memory:fd100000-fd11ffff
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
二楼那个貌似不对
解压出DEB安装应该就可以
应该是Realtek RTL8192EU chipset (0bda:818b)Bus 002 Device 003: ID 0bda:818b Realtek Semiconductor Corp.
解压出DEB安装应该就可以
https://sites.google.com/site/easylinux ... /reserve-7Realtek RTL8192EU chipset (0bda:818b)
6. For the Realtek chipset RTL8192EU you'll need to install a driver. That might sound complicated, but I've made it easy for you:
a. Download the following compressed driver package: driver for the RTL8192EU chipset
Background information: this driver package is an improved version of the driver package that the Maxxter company provided for a wireless dongle of theirs, which contains this chipset. The original driver only works in old versions of Ubuntu and Mint, but the improved version also works in Ubuntu 16.04 and Linux Mint 18 (thanks to Pilot6).
b. The package should have been downloaded into the folder Downloads. Simply double-click it like you would do for an installer package in Windows. It'll be installed automatically.
c. Then reboot your computer.
d. Plug the wireless dongle with the Realtek chipset into your computer: it should work now.
Note: do NOT install newer kernels, because then you'll probably lose the driver again! So in Linux Mint I advise to switch to the update policy "Don't break my computer!", which you can select by means of Update Manager (panel: Edit - Update policy). In Ubuntu I advise to pin Ubuntu to the current kernel (item 7, left column).
邮箱 chuan@ubuntu.org.cn
qy117121 写了:二楼那个貌似不对
解压出DEB安装应该就可以
为什么还是不行呢?按了安装重启以后什么反应都没有
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
