ubuntu 14.04 install TL-WN823N
Source code download
https://github.com/christiantroy/TL-WN823N-V2
Build and install
iwconfig
sudo ifconfig wlan0 up
Done.
If NOT find usb device please following step to fix it.
The rtw_usb_id_tbl array inside os_dep\Linux\usb_intf.c file defines all the vid/pids which this Realtek WiFi USB Linux driver supports currently. To support WiFi USB devices with new vid/pid(s) which is compatible with this driver, you can add the new vid/pid entries into the rtw_usb_id_tbl array. For example, adding 0x2019,0x4902 for CU and 0x07B8,0x8193 for DU compatible WiFi devices into rtw_usb_id_tbl array:
static struct usb_device_id rtw_usb_id_tbl[] ={ #ifdef CONFIG_RTL8192C /*=== Realtek demoboard ===*/
{USB_DEVICE(0x0BDA, 0x8191)},//Default ID … … …
{USB_DEVICE(0x0B05, 0x17AB)},//ASUS – Edimax
{USB_DEVICE(0x2019, 0x4902)}, //add here for CU compatible WiFi devices
#endif
#ifdef CONFIG_RTL8192D /*=== Realtek demoboard ===*/ /****** 8192DU ********/
{USB_DEVICE(USB_VENDER_ID_REALTEK, 0x8193)},//8192DU-VC … … …
/****** 8192DU-WiFi Display Dongle ********/
{USB_DEVICE(0x2019, 0xAB2D)},//Planex - Abocom ,5G dongle for WiFi Display
{USB_DEVICE(0x07B8, 0x8193)}, // add here for DU compatible WiFi devices
#endif {}
/* Terminating entry */
After adding the new vid/pid entries into the rtw_usb_id_tbl array, and re-compile the driver, the new driver image can support the device with the new vid/pid now
some wireless command
http://www.shumeipaiba.com/wanpai/jiaocheng/25.html
谁给翻译一下,怎么安装这个驱动 tl-wn823n v2
- 系统: Ubuntu19.10
Re: 谁给翻译一下,怎么安装这个驱动 tl-wn823n v2
插入设备(tl-wn823n v2) 执行以下指令将结果全部复制贴上来
uname -a
cat /etc/issue
lsusb
- 系统: Ubuntu19.10
wayoca@wayoca-desktop:~$ uname -a
Linux wayoca-desktop 4.4.0-47-generic #68-Ubuntu SMP Wed Oct 26 19:39:52 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
wayoca@wayoca-desktop:~$ cat /etc/issue
Ubuntu 16.04.1 LTS \n \l
wayoca@wayoca-desktop:~$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0bda:818b Realtek Semiconductor Corp.
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
0bda:818b 或为 rtl8192eu,较为常用的驱动为 https://github.com/Mange/rtl8192eu-linux-driverwayoca 写了:Bus 001 Device 004: ID 0bda:818b Realtek Semiconductor Corp.
或使用以下 PPA
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt update
sudo apt install rtl8192eu-dkms
- 系统: Ubuntu19.10
谢谢,我试试。
上面的好像是专用的
你提供的在用上个网卡时一直网络不好,第一步都没有过。
我把包下栽下载,
make
make instal
两步就可以了。
谢谢您的帮助。
上面的好像是专用的
我把包下栽下载,
make
make instal
两步就可以了。
谢谢您的帮助。
- 系统: Ubuntu19.10
vickycq 写了:0bda:818b 或为 rtl8192eu,较为常用的驱动为 https://github.com/Mange/rtl8192eu-linux-driverwayoca 写了:Bus 001 Device 004: ID 0bda:818b Realtek Semiconductor Corp.
或使用以下 PPA代码: 全选
sudo add-apt-repository ppa:hanipouspilot/rtlwifi sudo apt update sudo apt install rtl8192eu-dkms
正在读取软件包列表... 完成
正在分析软件包的依赖关系树
正在读取状态信息... 完成
将会同时安装下列软件:
dkms
下列【新】软件包将被安装:
dkms rtl8192eu-dkms
升级了 0 个软件包,新安装了 2 个软件包,要卸载 0 个软件包,有 0 个软件包未被升级。
需要下载 1,256 kB 的归档。
解压缩后会消耗 10.5 MB 的额外空间。
您希望继续执行吗? [Y/n]
获取:1 http://cn.archive.ubuntu.com/ubuntu xenial-updates/main amd64 dkms all 2.2.0.3-2ubuntu11.3 [66.1 kB]
获取:2 http://ppa.launchpad.net/hanipouspilot/rtlwifi/ubuntu xenial/main amd64 rtl8192eu-dkms all 4.4 [1,190 kB]
已下载 1,256 kB,耗时 42秒 (29.7 kB/s)
正在选中未选择的软件包 dkms。
(正在读取数据库 ... 系统当前共安装有 213371 个文件和目录。)
正准备解包 .../dkms_2.2.0.3-2ubuntu11.3_all.deb ...
正在解包 dkms (2.2.0.3-2ubuntu11.3) ...
正在选中未选择的软件包 rtl8192eu-dkms。
正准备解包 .../rtl8192eu-dkms_4.4_all.deb ...
正在解包 rtl8192eu-dkms (4.4) ...
正在处理用于 man-db (2.7.5-1) 的触发器 ...
正在设置 dkms (2.2.0.3-2ubuntu11.3) ...
正在设置 rtl8192eu-dkms (4.4) ...
Loading new rtl8192eu-4.4 DKMS files...
First Installation: checking all kernels...
Building only for 4.8.0-46-generic
Building for architecture x86_64
Building initial module for 4.8.0-46-generic
Error! Bad return status for module build on kernel: 4.8.0-46-generic (x86_64) 这是什么问题?怎么解决 感谢感谢
Consult /var/lib/dkms/rtl8192eu/4.4/build/make.log for more information.
猜测:此驱动 2016 年 11 月 01 日添加 Linux 4.7/4.8 支持,但 PPA 的 rtl8192eu-dkms - 4.4 最后一次构建在 2016 年 08 月 17 日,因此不包含 Linux 4.7/4.8 支持。您可以尝试使用 Linux 4.4。有关详细信息,请参阅 /var/lib/dkms/rtl8192eu/4.4/build/make.log。wayoca 写了:Building initial module for 4.8.0-46-generic
- 系统: Ubuntu19.10
我对底层,代码类的东西都不懂。 只是使用。 不过可以正常上网。不管了。谢谢谢谢vickycq 写了:猜测:此驱动 2016 年 11 月 01 日添加 Linux 4.7/4.8 支持,但 PPA 的 rtl8192eu-dkms - 4.4 最后一次构建在 2016 年 08 月 17 日,因此不包含 Linux 4.7/4.8 支持。您可以尝试使用 Linux 4.4。有关详细信息,请参阅 /var/lib/dkms/rtl8192eu/4.4/build/make.log。wayoca 写了:Building initial module for 4.8.0-46-generic
