WIFI突然无法连接
- 系统: Ubuntu 16.04
Re: WIFI突然无法连接
执行以下指令将结果全部复制贴上来
uname -a
cat /etc/issue
lspci -knn | grep -iA2 net
sudo lshw -numeric -C net
sudo iwlist scan
能提供更新的内容则更好,即 /var/log/apt/history.log 的内容spreadtrum 写了:是不是跟我更新了系统有关呢?
上次由 vickycq 在 2016-09-20 18:01,总共编辑 1 次。
- 系统: Ubuntu 16.04
Re: WIFI突然无法连接
vickycq 写了:执行以下指令将结果全部复制贴上来代码: 全选
uname -a cat /etc/issue lspci -knn | grep -iA2 net sudo lshw -numeric -C net sudo iwlist scan
~$ uname -a
Linux tj61184nbu 4.4.0-36-generic #55-Ubuntu SMP Thu Aug 11 18:01:55 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
test@tj61184nbu:~$ cat /etc/issue
Ubuntu 16.04.1 LTS \n \l
~$ lspci -knn | grep -iA2 net
06:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection [8086:4237]
Subsystem: Intel Corporation WiFi Link 5100 AGN [8086:1211]
Kernel driver in use: iwlwifi
07:00.0 Ethernet controller [0200]: Broadcom Corporation NetLink BCM5784M Gigabit Ethernet PCIe [14e4:1698] (rev 10)
Subsystem: Lenovo NetLink BCM5784M Gigabit Ethernet PCIe [17aa:3a26]
Kernel driver in use: tg3
Kernel modules: tg3
~$ sudo lshw -numeric -C net
*-network
product: PRO/Wireless 5100 AGN [Shiloh] Network Connection [8086:4237]
physical id: 0
bus info: pci@0000:06:00.0
logical name: wlp6s0
version: 00
serial: 00:26:c6:a5:b4:6a
width: 64 bits
clock: 33MHz
configuration: broadcast=yes driver=iwlwifi driverversion=4.4.0-36-generic firmware=8.83.5.1 build 33692 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
resources: irq:30 memory:f4500000-f4501fff
*-network
product: NetLink BCM5784M Gigabit Ethernet PCIe [14E4:1698]
vendor: Broadcom Corporation [14E4]
physical id: 0
bus info: pci@0000:07:00.0
logical name: enp7s0
version: 10
serial: c8:0a:a9:25:f7:26
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 duplex=full firmware=sb v2.09 ip=10.5.232.37 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:32 memory:f4600000-f460ffff
~$ sudo iwlist scan
enp7s0 Interface doesn't support scanning.
lo Interface doesn't support scanning.
wlp6s0 Scan completed :
Cell 01 - Address: 88:25:93:24:D3:F2
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=41/70 Signal level=-69 dBm
Encryption key:on
ESSID:"AP_TJ_APPS_11F3_Tools_CTS1"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=00000065f46136c0
Extra: Last beacon: 2832ms ago
IE: Unknown: 001A41505F544A5F415050535F313146335F546F6F6C735F43545331
IE: Unknown: 010882848B960C121824
IE: Unknown: 030101
IE: Unknown: 0706434E20010D20
IE: Unknown: 2A0100
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : PSK
IE: Unknown: 32043048606C
IE: Unknown: 2D1A6E101BFFFFFF0000000000000000008000000000000000000000
IE: Unknown: 331A6E101BFFFFFF0000000000000000008000000000000000000000
IE: Unknown: 3D1601050500000000000000000000000000000000000000
IE: Unknown: 341601050500000000000000000000000000000000000000
IE: WPA Version 1
Group Cipher : CCMP
IE: Unknown: DD180050F2020101030003A4000027A4000042435E0062322F00
IE: Unknown: DD0900037F01010000FF7F
Cell 02 - Address: 1C:1D:86:07:A1:71
Channel:1
Quality=29/70 Signal level=-81 dBm
Encryption key:on
ESSID:"SPRD_wireless"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 6 Mb/s; 9 Mb/s
11 Mb/s; 12 Mb/s; 18 Mb/s
Mode:Master
Extra:tsf=00000065cfad400d
Extra: Last beacon: 2840ms ago
IE: Unknown: 000D535052445F776972656C657373
IE: Unknown: 010882848B0C12961824
IE: Unknown: 030101
IE: Unknown: 0706434E20010D14
IE: Unknown: 0B050100558D5B
IE: Unknown: 2A0100
IE: Unknown: 2D1AAC191BFFFFFF0000000000000000000000000000000000000000
Group Cipher : CCMP
Authentication Suites (1) : 802.1x
IE: Unknown: 3D1601000500000000000000000000000000000000000000
IE: Unknown: 7F06001000000040
IE: Unknown: 851E09008F000F00FF03190041505F544A5F313146323500000000000100003C
IE: Unknown: 9606004096000300
IE: WPA Version 1
Group Cipher : CCMP
IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
IE: Unknown: DD06004096010104
IE: Unknown: DD050040960305
IE: Unknown: DD050040960B09
IE: Unknown: DD050040961401
Cell 03 - Address: 88:25:93:74:09:BA
Channel:6
Frequency:2.437 GHz (Channel 6)
Encryption key:on
ESSID:"AP_TJ_APPS_11F7_Tools_CTS3"
Mode:Master
Extra:tsf=0000006079191e46
Extra: Last beacon: 2668ms ago
IE: Unknown: 001A41505F544A5F415050535F313146375F546F6F6C735F43545333
IE: Unknown: 030106
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: Unknown: 3D1606050500000000000000000000000000000000000000
IE: Unknown: 341606050500000000000000000000000000000000000000
IE: WPA Version 1
Group Cipher : CCMP
Cell 04 - Address: 88:25:93:73:FA:AE
Channel:6
Quality=46/70 Signal level=-64 dBm
Encryption key:on
ESSID:"AP_TJ_APPS_11F9_Tools_CTS4"
Mode:Master
Extra:tsf=000000607943544b
Extra: Last beacon: 2704ms ago
IE: Unknown: 001A41505F544A5F415050535F313146395F546F6F6C735F43545334
IE: Unknown: 030106
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: WPA Version 1
Group Cipher : CCMP
Cell 05 - Address: 1C:1D:86:E9:6F:31
Channel:6
Encryption key:on
Mode:Master
Extra:tsf=00000060556871a2
IE: Unknown: 030106
IE: Unknown: 0B050A00B08D5B
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: Unknown: 3D1606000500000000000000000000000000000000000000
IE: Unknown: 7F020010
IE: Unknown: 851E07008F000F00FF03190041505F544A5F313146323100000000000A00003C
IE: WPA Version 1
Group Cipher : CCMP
Cell 06 - Address: BC:46:99:62:C0:EC
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=59/70 Signal level=-51 dBm
Encryption key:on
ESSID:"AP_TJ_APPS_11F10_2.4G"
Mode:Master
Extra:tsf=000000004274abeb
Extra: Last beacon: 2624ms ago
IE: Unknown: 001541505F544A5F415050535F31314631305F322E3447
IE: Unknown: 03010B
IE: Unknown: 0706434E20010D28
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: Unknown: 2D1AEF111BFFFFFF0000000000000000000100000000000000000000
IE: Unknown: 3D160B0F0600000000000000000000000000000000000000
IE: Unknown: 7F080000000000000040
IE: WPA Version 1
Group Cipher : CCMP
Cell 07 - Address: 1C:1D:86:E9:75:61
Channel:11
Quality=36/70 Signal level=-74 dBm
Encryption key:on
Mode:Master
Extra:tsf=00000065cf7bc620
Extra: Last beacon: 2488ms ago
IE: Unknown: 03010B
IE: Unknown: 0B0504002D8D5B
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: Unknown: 3D160B000500000000000000000000000000000000000000
IE: Unknown: 851E05008F000F00FF03190041505F544A5F313146323300000000000400003C
IE: WPA Version 1
Group Cipher : CCMP
Cell 08 - Address: 1C:1D:86:0F:25:91
Channel:1
Quality=35/70 Signal level=-75 dBm
Encryption key:on
Mode:Master
Extra:tsf=00000065cf9e0953
Extra: Last beacon: 2848ms ago
IE: Unknown: 030101
IE: Unknown: 0B050700438D5B
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: Unknown: 851E09008F000F00FF03190041505F544A5F313146323400000000000700003C
IE: WPA Version 1
Group Cipher : CCMP
Cell 09 - Address: 9C:21:6A:FA:9E:E3
Channel:6
Quality=32/70 Signal level=-78 dBm
Encryption key:on
ESSID:"AP_TJ_PLDAPPS_11F4_2.4G"
Mode:Master
Extra:tsf=0000000030bc9180
Extra: Last beacon: 2784ms ago
IE: Unknown: 001741505F544A5F504C44415050535F313146345F322E3447
IE: Unknown: 030106
IE: Unknown: 05050001002201
IE: Unknown: 2A0100
IE: Unknown: 2D1AEF121BFFFFFF00000000000000000000000000000406E6E70D00
IE: Unknown: DD180050F2020101850003A4000027A4000042435E0062322F00
IE: Unknown: DD180050F204104A00011010440001021049000600372A000120
Group Cipher : CCMP
IE: WPA Version 1
Group Cipher : CCMP
Cell 10 - Address: 44:AD:D9:06:44:11
Channel:11
Quality=28/70 Signal level=-82 dBm
Encryption key:on
Mode:Master
Extra:tsf=00000065cc690e21
Extra: Last beacon: 2612ms ago
IE: Unknown: 03010B
IE: Unknown: 0B050500558D5B
IE: Unknown: 2A0100
IE: Unknown: 2D1A2C181BFFFF000000000000000000000000000000000000000000
Group Cipher : CCMP
IE: Unknown: 851E06008F000F00FF03190041505F544A5F313146323700000000000500003A
IE: Unknown: 9606004096000000
IE: WPA Version 1
Group Cipher : CCMP
Cell 11 - Address: BC:46:99:62:C0:EE
Channel:153
Frequency:5.765 GHz
Quality=45/70 Signal level=-65 dBm
Encryption key:on
ESSID:"AP_TJ_APPS_11F10_5G"
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
Mode:Master
Extra:tsf=00000065e2801867
Extra: Last beacon: 228ms ago
IE: Unknown: 001341505F544A5F415050535F31314631305F3547
IE: Unknown: 01088C129824B048606C
IE: Unknown: 030199
IE: Unknown: 071E434E202401282801282C01283001289501289901289D0128A10128A50128
IE: Unknown: 200103
Group Cipher : CCMP
IE: Unknown: 2D1AEF091BFFFFFF0000000000000000000100000000000000000000
IE: Unknown: 3D16990F0400000000000000000000000000000000000000
IE: Unknown: BF0CB2018033EAFF0000EAFF0000
IE: Unknown: C005019B00FCFF
IE: Unknown: C30402B0B0B0
IE: WPA Version 1
Group Cipher : CCMP
Cell 12 - Address: 1C:1D:86:E9:75:6E
Channel:157
Frequency:5.785 GHz
Quality=23/70 Signal level=-87 dBm
Encryption key:on
Mode:Master
Extra:tsf=00000065cf406fc9
Extra: Last beacon: 216ms ago
IE: Unknown: 0706434E2095051E
IE: Unknown: 0B050000058D5B
Group Cipher : CCMP
IE: Unknown: 3D169D080400000000000000000000000000000000000000
IE: Unknown: 851E00008F000F00FF03190041505F544A5F313146323300000000000000003B
IE: Unknown: 9606004096000200
IE: WPA Version 1
Group Cipher : CCMP
Cell 13 - Address: 1C:1D:86:E9:6F:3E
Channel:161
Frequency:5.805 GHz
Quality=31/70 Signal level=-79 dBm
Encryption key:on
Mode:Master
Extra:tsf=00000065cf75204b
Extra: Last beacon: 120ms ago
IE: Unknown: 0B050000028D5B
Group Cipher : CCMP
IE: Unknown: 3D16A1080400000000000000000000000000000000000000
IE: Unknown: 851E01008F000F00FF03190041505F544A5F313146323100000000000000003B
IE: WPA Version 1
Group Cipher : CCMP
Cell 14 - Address: 08:62:66:98:51:84
Channel:165
Frequency:5.825 GHz
Quality=34/70 Signal level=-76 dBm
Encryption key:on
ESSID:"AP_TJ_APPS_11F5_5G"
Mode:Master
Extra:tsf=00000065ded22164
Extra: Last beacon: 84ms ago
IE: Unknown: 001241505F544A5F415050535F313146355F3547
IE: Unknown: 050400030180
Group Cipher : CCMP
IE: Unknown: 0B050B00040000
IE: Unknown: 2D1AAD0917FFFFFF0000000000000000000000000000000000000000
IE: Unknown: 3D16A5080400000000000000000000000000000000000000
IE: Unknown: 7F080400080000000040
IE: Unknown: BF0CB259820FEAFF0000EAFF0000
IE: Unknown: C00500A5000000
IE: Unknown: C3020002
IE: Unknown: DD09001018020B001C0000
IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
IE: Unknown: 46057208010000
Cell 15 - Address: 08:62:66:C1:44:AC
Channel:165
Frequency:5.825 GHz
Encryption key:on
ESSID:"AP_TJ_APPS_11F6_5G"
Mode:Master
Extra:tsf=00000065df029050
Extra: Last beacon: 72ms ago
IE: Unknown: 001241505F544A5F415050535F313146365F3547
IE: Unknown: 05050203000004
Group Cipher : CCMP
IE: Unknown: 0B050500030000
IE: Unknown: DD090010180205001C0000
~$ turan
- 系统: Ubuntu 16.04
Re: WIFI突然无法连接
这是什么原因呢?命令都是什么意思?
Re: WIFI突然无法连接
iwlist scan 正常输出扫描结果。目前主贴图所示菜单有无列出扫描结果?若仍未列出扫描结果,尝试重启 NetworkManager, nm-applet
若仍未列出扫描结果,可查看执行以上代码过程中的系统日志寻找问题
sudo pkill nm-applet
sudo systemctl restart NetworkManager
nm-applet&
原因待确定spreadtrum 写了:这是什么原因呢?
收集信息以利诊断spreadtrum 写了:命令都是什么意思?
