broadcom的驱动安装
- 系统: win10
broadcom的驱动安装
在附加驱动中直接安装,会卡死
重启之后附加驱动中就没这驱动了,wifi也用不了
不知道该怎么弄了
不知道该怎么弄了
Re: broadcom的驱动安装
先提供无线网卡型号,操作系统版本,内核版本
把结果全部复制贴上来
uname -a
cat /etc/issue
lspci -knn
sudo lshw -C network
- 系统: win10
Re: broadcom的驱动安装
lwc@lwc-Lenovo-Gaming:~$ uname -avickycq 写了:先提供无线网卡型号,操作系统版本,内核版本把结果全部复制贴上来代码: 全选
uname -a cat /etc/issue lspci -knn sudo lshw -C network
Linux lwc-Lenovo-Gaming 3.19.0-28-generic #30~14.04.1-Ubuntu SMP Tue Sep 1 09:32:55 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
lwc@lwc-Lenovo-Gaming:~$ cat /etc/issue
Ubuntu 14.04.3 LTS \n \l
lwc@lwc-Lenovo-Gaming:~$ lspci -knn
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller [8086:0c04] (rev 06)
Subsystem: Lenovo Device [17aa:3830]
00:02.0 VGA compatible controller [0300]: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller [8086:0416] (rev 06)
Kernel driver in use: i915
00:03.0 Audio device [0403]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller [8086:0c0c] (rev 06)
00:14.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI [8086:8c31] (rev 05)
00:16.0 Communication controller [0780]: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 [8086:8c3a] (rev 04)
Kernel driver in use: mei_me
00:1a.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 [8086:8c2d] (rev 05)
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller [8086:8c20] (rev 05)
00:1c.0 PCI bridge [0604]: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 [8086:8c10] (rev d5)
00:1c.2 PCI bridge [0604]: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 [8086:8c14] (rev d5)
00:1c.3 PCI bridge [0604]: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 [8086:8c16] (rev d5)
00:1d.0 USB controller [0c03]: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 [8086:8c26] (rev 05)
00:1f.0 ISA bridge [0601]: Intel Corporation HM87 Express LPC Controller [8086:8c4b] (rev 05)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] [8086:8c03] (rev 05)
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller [8086:8c22] (rev 05)
00:1f.6 Signal processing controller [1180]: Intel Corporation 8 Series Chipset Family Thermal Management Controller [8086:8c24] (rev 05)
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Lenovo Device [17aa:3838]
Kernel driver in use: r8169
03:00.0 Network controller [0280]: Broadcom Corporation Device [14e4:43ae] (rev 02)
Subsystem: Lenovo Device [17aa:0622]
lwc@lwc-Lenovo-Gaming:~$ sudo lshw -C network
[sudo] password for lwc:
*-network
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 15
serial: 68:f7:28:f5:2e:44
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.0.101 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:31 ioport:3000(size=256) memory:c0904000-c0904fff memory:c0900000-c0903fff
*-network UNCLAIMED
product: Broadcom Corporation
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 02
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: memory:c0800000-c0807fff memory:c0400000-c07fffff
Re: broadcom的驱动安装
此卡型号为 BCM43162。目前 (2015-09) 主流驱动 (b43, brcm80211, wl) 均不支持此卡。03:00.0 Network controller [0280]: Broadcom Corporation Device [14e4:43ae] (rev 02)
参考:
https://bugs.launchpad.net/ubuntu/+sour ... ug/1432869
http://askubuntu.com/questions/644617/b ... 3ae-rev-02
http://askubuntu.com/questions/596934/b ... patibility
https://wikidevi.com/wiki/Broadcom_BCM943162ZP
- 系统: win10
Re: broadcom的驱动安装
意思是说装不了无线驱动是吗?vickycq 写了:此卡型号为 BCM43162。目前 (2015-09) 主流驱动 (b43, brcm80211, wl) 均不支持此卡。03:00.0 Network controller [0280]: Broadcom Corporation Device [14e4:43ae] (rev 02)
参考:
- 系统: win10
Re: broadcom的驱动安装
尝试了一下用ndisgtk,安装windos得无线驱动vickycq 写了:此卡型号为 BCM43162。目前 (2015-09) 主流驱动 (b43, brcm80211, wl) 均不支持此卡。03:00.0 Network controller [0280]: Broadcom Corporation Device [14e4:43ae] (rev 02)
参考:
http://www.kafan.cn/edu/4489501.html
我下载的是win8的官方驱动,解压,添加驱动后也没有要我确定“5、可能会弹出提示说“不能确定硬件是否存在”,点“确定”。”
满心欢喜,结果还是用不了
Re: broadcom的驱动安装
r8169 不是合適驅動product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
search.php?keywords=8111+r8169&terms=al ... C%E5%B0%8B
如果你有有線連網 請先解決這個問題後
再貼文處理 無線網卡問題
Re: broadcom的驱动安装
型号较新,目前来看无法(方便地)驱动。你可以仔细阅读参考链接,没看到成功案例。nistar90 写了: 意思是说装不了无线驱动是吗?
Re: broadcom的驱动安装
1. sudo cat /usr/share/misc/pci.ids | grep 43aelspci -knn
沒有 43ae
2. http://pciids.sourceforge.net/v2.2/pci.ids
使用 43ae 搜尋
沒有 43ae
3. 沒有 43ae 無法確認 型號
4. 你有安裝 windows 嗎此卡型号为 BCM43162
請進 Windows 裝置管理員 / 無線網卡 / 屬性
確認 型號 / vendor ID / product ID
- 系统: win10
Re: broadcom的驱动安装
poloshiao 写了: 4. 你有安裝 windows 嗎
Broadcom 802.11ac Metwork Adapter
Re: broadcom的驱动安装
這個不是Broadcom 802.11ac Metwork Adapter
請詳細點選 屬性裡面的每一項
因為 你的 lspci 偵測到的不一定準確
所以要從 Windows 確認
Re: broadcom的驱动安装
开源驱动b43还不支持博通pci-id为14e4:43a0的无线网卡,14e4:43a0有bcm4360和bcm4352两种chip-id,硬件接口类型也分两种,分别是pci和pcie,它推荐用博通的专有驱动wl,在这里有说明:
https://wireless.wiki.kernel.org/en/use ... ed_devices 先确认无线网卡型号:
安装关联的broadcom-sta-dkms软件包,连带wireless-tools也安装了,安装完成以后,dkms会为系统构建wl模块:
卸载有冲突的模块:
加载wl模块:
下一步就是配置无线路由器与连接wifi。
lspci -nn | grep 0280
sudo apt-get update
sudo apt-get install linux-headers-$(uname -r|sed 's,[^-]*-[^-]*-,,') broadcom-sta-dkms
sudo modprobe -r b44 b43 b43legacy ssb brcmsmac
sudo modprobe wl
Re: broadcom的驱动安装
1. 43a0 與 43ae 不同lspci -knn
2. 43ae 是否正確
從 Windows 裝置管理員 確認 是一個方向
Re: broadcom的驱动安装
没看真切,错了一个字符,不过,要是连broadcom-sta都无法驱动这硬件,那只好去改驱动代码。内存不大的话,可以将系统换成i386架构的,用ndiswrapper来安装32位的驱动,因为ndiswrappe对32位的驱动支持得更全面。又或者,什么都别做,有时候等上一等往往才是最明智的选择。poloshiao 写了:14e4:43a0有bcm4360和bcm4352两种chip-id1. 43a0 與 43ae 不同lspci -knn
2. 43ae 是否正確
Re: broadcom的驱动安装
没看错的话楼主是联想机器?可恶的联想,想换都换不了。ReverseOnce 写了:有时候等上一等往往才是最明智的选择。
如果楼主坚持要用Linux,可以找人修改 Bios 去掉白名单,再买一块其它厂牌的卡换上。
https://www.bios-mods.com/forum/
