### MBR 分割表類型引導
範例: Linux Mint 18.3 引導 OpenSolaris Dev svn 134 (MBR 分割區)
Solaris 安裝完成後,打開終端機執行 Format 查看分割與分片區狀態
* 查看分割區狀態
# format
> 0
> fdisk
Total disk size is 4177 cylinders
Cylinder size is 16065 (512 byte) blocks
Cylinders
Partition Status Type Start End Length %
1 Active Linux native 0 2088 2089 50
2 Solaris2 2088 4175 2088 50
Solaris 安裝在第二分割區
* 查看分片狀態
# format
> partition
partition> p
Current partition table (original):
Total disk cylinders available: 2086 + 2 (reserved cylinders)
Part Tag Flag Cylinders Size Blocks
0 unassigned wm 0 0 (0/0/0) 0
1 root wm 1 - 2085 15.97GB (2085/0/0) 33495525
2 backup wu 0 - 2085 15.98GB (2086/0/0) 33511590
3 unassigned wm 0 0 (0/0/0) 0
4 unassigned wm 0 0 (0/0/0) 0
5 unassigned wm 0 0 (0/0/0) 0
6 unassigned wm 0 0 (0/0/0) 0
7 unassigned wm 0 0 (0/0/0) 0
8 boot wu 0 - 0 7.84MB (1/0/0) 16065
9 unassigned wm 0 0 (0/0/0) 0
zfs根目錄是在 root 分片
不會修復 Linux Grub2 的,先安裝 Solaris 然後再安裝 Linux
然後進到 Linux 編輯 /boot/grub/grub.cfg Grub2選單
加入 OpenSolaris 引導
# MBR第二分割區 = msdos2
# boot 分片 8 = sunpc9 (+1就對了)
引導參數如下:
menuentry 'OpenSolaris 2010 svn 134' {
insmod part_msdos
insmod part_sunpc
insmod part_gpt
insmod zfs
set root='hd0,msdos2,sunpc9'
chainloader (hd0,msdos2,sunpc9)+1
### GPT 分割表類型引導
範例: Kali Linux 引導 OpenIndiana 2018.04 hipster (GPT 分割區)
* 安裝注意事項:
與 Linux 共存安裝在其他的GPT分割區,現在好像只能使用手動安裝,OpenIndiana Live 裡面沒提供 gdisk,所以必須在Live系統內下載gdisk,預先分割Solaris安裝空間。
然後使用腳本安裝。或者參考 https://forum.ubuntu.org.cn/viewtopic.p ... 5&t=488510
安裝腳本:
https://github.com/Mint-Fans/linux-package/raw/Solaris/Live-Install-Script.tar.gz
https://github.com/Mint-Fans/linux-package/raw/Solaris/gptfdisk-1.0.3.tar.gz
* 分割OpenIndiana安裝空間
# gdisk /dev/dsk/c4t2d0
Command (? for help): n
Partition number (2-128, default 2):
First sector (34-67108830, default = 33554432) or {+-}size{KMGTP}:
Last sector (33554432-67108830, default = 67108830) or {+-}size{KMGTP}:
Hex code or GUID (L to show codes, Enter = BF01):
Changed type of partition to 'Solaris /usr & Mac ZFS'
Command (? for help): p
Number Start (sector) End (sector) Size Code Name
1 2048 33554431 16.0 GiB 8300
2 33554432 67108830 16.0 GiB BF01 Solaris /usr & Mac ZFS
Command (? for help): w
Y
第二分割區為OpenIndiana安裝空間
* 查看分片狀態
# format
> partition
partition> p
Part Tag Flag First Sector Size Last Sector
0 unassigned wm 0 0 0
1 usr wm 33554432 16.00GB 67108830
2 unassigned wm 0 0 0
3 unassigned wm 0 0 0
4 unassigned wm 0 0 0
5 unassigned wm 0 0 0
6 unassigned wm 0 0 0
s0 是第一分割區
s1 是第二分割區
然後使用腳本安裝,或者參考 https://forum.ubuntu.org.cn/viewtopic.p ... 5&t=488510
一樣,不會修復 Linux Grub2 的,先安裝 Solaris 然後再安裝 Linux
加入 OpenIndiana 引導
# GPT第二分割區 = gpt2
# GPT 類型不必指定分片了
引導參數如下:
menuentry 'OpenIndiana 2018.04 hipster' {
insmod part_gpt
set root='hd0,gpt2'
chainloader (hd0,gpt2)+1
### 甲骨文官方公佈的Grub2引導參數分析
甲骨文官方公佈的引導參數還沒在 OpenSolaris / OpenIndiana 上面測試成功。
OpenSolaris 只支援 MBR 分割區安裝,Solaris 11 或 OpenIndiana 支援 MBR 與 GPT 分割區安裝。
分析一下甲骨文官方公佈的引導參數
menuentry "<title>" {
insmod part_msdos
insmod part_sunpc
insmod part_gpt
insmod zfs
search --no-floppy --fs-uuid --set=root bbb75569aebe4013
set be_name=opensolaris
zfs-bootfs /ROOT/$be_name/@/ zfs_bootfs
set kern=/platform/i86pc/kernel/amd64/unix
echo -n "Loading ${root}/ROOT/$be_name/@$kern: "
$multiboot /ROOT/$be_name/@/$kern $kern -B $zfs_bootfs
set gfxpayload="1024x768x32;1024x768x16;800x600x16;640x480x16;640x480x15;640x480x32"
insmod gzio
echo -n "Loading ${root}/ROOT/$be_name/@/platform/i86pc/amd64/boot_archive: "
$module /ROOT/$be_name/@/platform/i86pc/amd64/boot_archive
search --no-floppy --fs-uuid --set=root bbb75569aebe4013 這一行其實可以改成 set root='hd0,msdos2,sunpc2'也就是指向 root 分片。
或者改成 search --set=root --label rpool --hint hd0,msdos2 自動搜尋 rpool 標籤。
