範例 UBB.threads 7.5.9
UBB.threads 官方載點(需註冊會員)
https://www.ubbcentral.com/members/downloads.php
僅支援 php 5
下載安裝網頁系統(備份連結)
wget https://github.com/Mint-Fans/linux-package/raw/master/ubbthreads-7-5-9.zip
unzip ubbthreads-7-5-9.zip
mv ubbthreads-7-5-9 ubbthreads
sudo mv ubbthreads /var/www/html/
sudo chmod -R 777 /var/www/html/ubbthreads/includes
sudo chmod 666 /var/www/html/ubbthreads/includes/*
sudo chmod -R 777 /var/www/html/ubbthreads/sessions
sudo chmod -R 777 /var/www/html/ubbthreads/templates/compile
sudo chmod -R 777 /var/www/html/ubbthreads/cache
sudo chmod -R 777 /var/www/html/ubbthreads/cache_builders
sudo chmod -R 777 /var/www/html/ubbthreads/cache_builders/custom
sudo chmod 666 /var/www/html/ubbthreads/cache_builders/custom/*
sudo chmod -R 777 /var/www/html/ubbthreads/styles
sudo chmod 666 /var/www/html/ubbthreads/styles/*
sudo chmod -R 777 /var/www/html/ubbthreads/tmp
sudo chmod -R 777 /var/www/html/ubbthreads/gallery
sudo chmod -R 777 /var/www/html/ubbthreads/gallery/default
mysql -u root -p
> create database ubbthreads;
> show databases;
> quit
打開瀏覽器, 輸入以下網址, Enter 開始安裝.
http://localhost/ubbthreads/install/
If you are doing an initial install of UBB.threads™, 點選 Go here.
點選 proceed to next step
設定資料庫名稱(Database name) 輸入密碼, 然後點選 check datebase settings
點選 Next Step
Custom cookie prefix 可空白, 點選 check settings
點選 Next Step
現在有兩個選項
1.creating your admin user 建立管理員帳號
2.Creating your tables 建立資料表
選擇 creating your admin user
進到這裡建立管理員帳號, 然後點選 Submit Admin User Info
完成註冊點選 proceed to next step
建立資料表後, 點選下面的 click here 連結, 進入首頁
完成
